X-Mem (Extension mémoire)
Aller à la page: <  1, 2
MessagePosté le: Mer 27 Avr - 23:56 (2016)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
Well, it would make thing more easy I guess. But never mind what people ask at first. As long as it works stable it's all fine. Later you still can use 'special features' if you like. At the moment it would just be nice to have one DOS running with the X-MASS at all.  Very Happy
MessagePosté le: Mer 27 Avr - 23:56 (2016)    Sujet du message: Publicité
MessagePosté le: Ven 6 Jan - 16:58 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
News / Update for the X-MEM from Tot0...
The 512 KB static RAM (SRAM) IC of the X-MEM (or Y-MEM) can be replaced by the M48Z512 or M48T512 IC.
- The M48Z512 is a non volatile RAM (NVRAM).
  It allows to keep the memory content (f.e. RAM drive) even after the CPC is turned off.
  It cost between $6 and $15.
- The M48T512 is a TIMEKEEPER.
  It's like the M48Z512 (provides same NVRAM functionality). And in addition if provides a real-time-clock (RTC).
  The last 8 bytes are used for the embedded RTC.
  Than means when using the X-MEM you switch on the RAM &FF by OUT &7FFF,&FF.
  And then read or write the date / time data from or to &7FF8-&7FFF.
  It cost between $20 and $25.
MessagePosté le: Ven 6 Jan - 17:10 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
really interresting ^^
MessagePosté le: Lun 9 Jan - 21:31 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
Yes, have to get the chips and experiment with them Smile
MessagePosté le: Lun 9 Jan - 22:08 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
i need one of these card!
MessagePosté le: Mar 10 Jan - 16:10 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
Just Email Tot0.  Very Happy
MessagePosté le: Mar 10 Jan - 16:16 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
That's not a bad idea !
MessagePosté le: Mer 11 Jan - 08:47 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
déjà fait
je crois qu'il faudra être très patient
et encore, il m'avait répondu avant que la sombre histoire cpcwiki commence...
already done, i have to be patient and lucky
that was before the cpcwiki story...
MessagePosté le: Mer 11 Jan - 17:04 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
He won't forget you. He is just very disappointed how people treated him in CPCWiki forum. And he got my full understanding. Also I guess he is pretty busy with private issues, real life.
MessagePosté le: Dim 11 Juin - 23:01 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
Pour la petite histoire, avec TotO, nous avons profité à l'occasion du mini meeting orgainsé ce week end, pour parler du fameux bugs des extensions memoires qui se produit uniquement quand l'asic est utilisé conjointement avec les banques mémoires.
Nous avons fait des tests.... et.... une solution a été envisagée, autre que celle que nous avions trouvé avec Gerald et Arnoldemu, il y a déjà quelques temps (remettre les banks à zero -&c0- avant chaque appel à l'asic)
L'extension Xmem, et je parle seulement de celle ci, utilise deux ports bien distincts, le port #7f (connexion ram extension externe) et le port #7e, (connexion ram 64k supplementaire interne)
Afin de résoudre ce bug sur les programmes ou démos qui étaient impactées (par exemple : aintro 2 (Roudoudou), synergy, rst#38...etc), il suffit d'appeler les banks mémoires supplémentaires (c4, c5, c6, c7 mais aussi c1,c2 et c3) via le port #7e.
Ceci peut également permettre de récupérer 64k de ram, en plus des 512k proposés par l'extension, pemettant ainsi de passer de 512 à 640k. (512+128) Elle est pas belle la vie ?
Par contre, il faudra copier/loader vos data en connectant vos banks mémoires en utilisant le port #7e au lieu du port #7f.
Par exemple, en basic :
Memory &3fff
Out &7e00,&c5 ; connecte la memoire interne 6128 plus bank c5
Load"data.bin",&4000
Un truc rapide pour détecter la X-mem :
Ld bc,&7ec5 ; connecte bank #c5 interne
Out(c),c
Ld hl,#4000
Ld a,#f2
Ld (hl),a ; on poke la val #f2
Inc b
Out (c),c ; connecte la memoire externe bank #c5
Ld a,#aa
Ld (hl),a ; poke la val #aa
Dec b
Out (c),c ; connecte memoire interne bank #c5
Ld d,(hl) ; recupère la val dans d
Sub d ; 2 possibilitées -> si d=0 la xmem n'est pas connectée, 2eme cas d=#f2 la memoire interne supp bank #c5 est connectée.
Voilà, je tenais à vous livrer le résultat de nos recherches, comme quoi, on a pas "que rien foutu" durant ce week end. (Sauf
MacDeath peut être, et encore...!)
MessagePosté le: Lun 12 Juin - 11:39 (2017)    Sujet du message: X-Mem (Extension mémoire) Répondre en citant
Pas mal tout ça  Okay
MessagePosté le: Aujourd’hui à 18:43 (2018)    Sujet du message: X-Mem (Extension mémoire)
Page 2 sur 2
